2nd Gen Durango 2004 - 2009
Newbie w/ quick question
Old May 24, 2006 | 12:12 AM
shelby69's Avatar
shelby69
Default Newbie w/ quick question
I searched, but came up dry.
I just bought a 04 Durango Limited 5.7 with towing package. I the owners manual it talks about putting the transfer-case in neutral to tow? Does this make it just be rear-wheel-drive? If so, could I use this for regular everyday driving? Thus, getting a little better gas milage and saving wear-and-tear. Just curious.
Thanks
Old May 25, 2006 | 01:45 AM
mmcg24's Avatar
mmcg24
Default RE: Newbie w/ quick question
Are you sure this is right? I can't see how you can function with the transfer in neutral. All available ranges at this point are/ should be disengaged.
Old May 25, 2006 | 09:45 AM
jasonwyo's Avatar
jasonwyo
When you put the transfer case in neutral, this 100% disengages the drive train making the vehicle ready to be towed. This is intended for towing behind a RV or tow truck. If you have a 4wd durango, most likley it is AWD, and then can be locked in 4HI or 4LO by turning the ****.
Old May 26, 2006 | 12:27 AM
shelby69's Avatar
shelby69
Oh Ok. I got you, so if I wanted to tow the truck behind a motorhome or something. Thanks
Sorry for being a dumbass
