2nd Gen Durango 2004 - 2009
durango 2004 no high beam
Old Nov 27, 2006 | 02:23 PM
pgtek's Avatar
pgtek
Default durango 2004 no high beam
Hi
i had high beams yesterday
today i flip the lever to have high beams, the indicator light in the dash comes on but no high beam
the low beams works fine
is there a fuse or realy under the hood for those
thanks
Old Nov 27, 2006 | 04:44 PM
Mean Green's Avatar
Mean Green
Default RE: durango 2004 no high beam
It may just be the bulbs. Time to replace them with some HID's.
Old Nov 27, 2006 | 10:33 PM
pgtek's Avatar
pgtek
hi
can both be burn at the same time????????????
Old Nov 27, 2006 | 11:22 PM
Hemi4wheeling's Avatar
Hemi4wheeling
More than likely one of your bulbs are bad. Go buy one and try each bulb to see if it fixes it. If not it could be the relay under the hood. IF it's not that than your switch is bad. The switch is the control stick. Always go the cheapre route first.
Old Nov 28, 2006 | 10:13 AM
pgtek's Avatar
pgtek
Hi
thank for the feedback
I look under the hood and cant see the realy i have 2 boxes there and i see nothing about headlamp
where is it?????????????
what does it looks like ?????????
cheers
