2nd Gen Durango 2004 - 2009
04 durango a/c not working.
Old Jan 17, 2007 | 08:57 PM
2ndtime04gt's Avatar
2ndtime04gt
Default 04 durango a/c not working.
Got in the truck today and the a/c wont utrn on. No defrost, heat, air nothing. Could it be a fuse, if so, where is it located?
Old Jan 26, 2007 | 05:14 AM
vjclark's Avatar
vjclark
Default RE: 04 durango a/c not working.
Own a 2005 Durango. Just had to replace the blower motor resistor because I had no blowing air (just heat). Discovered the ground wire had insulation burnt off and it's connecting point in the resistor was melted! Replaced the resistor, but this problem will reoccur as there is no fix (as of yet) for the heat coming through the ground wire. Chrysler needs a recall for this problem! The resistor is a dealer part that sells for less than $20. It's located under the passenger footwell but be sure to disconnect and isolate the battery negative cable before replacing the resistor.
