2nd Gen Intrepid 1998 through 2004 Intrepids
code 0160 98 2.7 motor
Old Apr 3, 2007 | 01:38 AM
gus1967's Avatar
gus1967
Default code 0160 98 2.7 motor
Got a code 160 and the check engine light is on.I know the code means no activity fron o2 sensor bank 2 sensor 2.Has anyone found that to NOT be a bad sensor?I hate to throw a part at this and find out I am wrong..I do not have a scanner to check it out correctly.
Also how do you reset the codes? I had a 95 neon and use to disconnect the battery and short the leads to each other to reset the codes.Does that hold true for the intrepid?
Old Apr 3, 2007 | 10:29 AM
gus1967's Avatar
gus1967
Default RE: code 0160 98 2.7 motor
Update...disconnecting the positive lead from the battery and shorting itto the negative terminal DOES reset the codes.Just tryed it and it works like a champ.
