2nd Gen Intrepid 1998 through 2004 Intrepids
Intrepid Door Seals, locks, headlights, etc.
Old Apr 7, 2007 | 04:41 AM
gskurka's Avatar
gskurka
Default Intrepid Door Seals, locks, headlights, etc.
Is there a fix for the shrinking door seals on the 2nd generation Intrepids. My seals were replaced once at the stealer and they're pulling away from the frame again. What is the cost for new seals? I'd like to know if this issue has been resolved. The other common problems with this car: screaming door locks, rear trunk release and trunk light are inoperative, cloudy headlight lenses and the A/C won't hold a charge. I put in UV leak detector and my fear is that the evaporator is leaking. Howdifficult is it to remove and replace?
Any suggestions are appreciated.
Greg
Old May 7, 2007 | 01:50 PM
KaiGywer's Avatar
KaiGywer
Default RE: Intrepid Door Seals, locks, headlights, etc.
Anybody? I have those shrinking seals as well. Annoying in the car wash (I'm washing my car, not my hair...)
Old Sep 7, 2007 | 10:22 PM
cnkulas's Avatar
cnkulas
had the same shrinking seals on my 2000 intrepidi took the door sills up ,slit the seal pulled the seal
tight around the door frame and with pieces cut from asalvage yard seal filled the gap then replaced the door sill had no problem with air or water leaks and its barely noticeable
Old Jun 7, 2008 | 12:04 AM
gskurka's Avatar
gskurka
Thanks for the input. I performed a similar fix without additional material at the door sill. I also used 3M weatherstrip adhesive to hold the rubber in place around the top of the door frame.
Greg
