2nd Gen Intrepid 1998 through 2004 Intrepids
any clue?
Old Jun 3, 2007 | 03:19 PM
damnadodge's Avatar
damnadodge
Default any clue?
changed thermo housing gasket and thermo....thought there was a leak from there...not the case its leaking from a small hole under the thermo housing.dont know what this hole is....water pump is working fine so why would it be leaking if some sort of pressure relief?also has a hissing and gurgling from under the plenum somewhere....
Old Jun 3, 2007 | 03:46 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: any clue?
u have an intake gasket leak see it a few times u have a 5.9 or 5.2 right? U get to remove the intake and lower intake and replace some gaskets.
Old Jun 3, 2007 | 03:47 PM
Dodge Tech's Avatar
Dodge Tech
my bad ignore that i said i thought it was a truck hehe
Old Jun 3, 2007 | 03:48 PM
damnadodge's Avatar
damnadodge
its a 2.7....intrepid
Old Jun 3, 2007 | 03:52 PM
Dodge Tech's Avatar
Dodge Tech
lets see u changed the thermostat under the car on the driver side?
Old Jun 3, 2007 | 03:54 PM
damnadodge's Avatar
damnadodge
yep...housing gasket and thermostat.....thought the leak was from there...but there is a small hole under the housing....the car ran hot the other night because of a wire shortage(harness in the pulley)got the wires right now the hole leaks.....and it seems to be gurgling from under the plenum......is this hole a relief for a bad water pump?the pump is working fine ....so what could it be?
Old Jun 3, 2007 | 03:58 PM
Dodge Tech's Avatar
Dodge Tech
the plemum is on top the work u did was under the car did u bleam out the air that is there now from u removing teh thermostat? the housing on top of the engine there is a 10mm bleader screw open it up a few time while the engein is running.
Old Jun 3, 2007 | 04:00 PM
damnadodge's Avatar
damnadodge
well when i put water in it...it just pours out of this hole under the housing....so im trying to fix that before i go to the plenum issue...but no...i havent tried bleeding it yet untill i can get this hole stopped up....
Old Jun 3, 2007 | 04:06 PM
Dodge Tech's Avatar
Dodge Tech
is it leaking up top or under the car where u did the work at?? can u see it. u cant see the water pump its inside the engine.
Old Jun 3, 2007 | 04:07 PM
damnadodge's Avatar
damnadodge
you can actually see it coming from this hole under the housing....leaking from the bottom of the car...
