2nd Gen Intrepid 1998 through 2004 Intrepids
oil light comes on..
Old Oct 3, 2007 | 09:10 PM
springerdw's Avatar
springerdw
Default oil light comes on..
So is this the fix for 2000 Intrepid’s with 2.7L engines. The below post stated it’s for 1999 model years. I understand when it was written the year 2000 wasn't here yet. I just want to make sure this is an option before I buy the order the part.
NO: 08-36-99 SUBJECT: Engine Oil Pressure Light Flicker DATE: Oct. 15, 1999 OVERVIEW: This bulletin involves adding a terminal/wire/vent to the oil pressure switch connector. NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 2.7L ENGINE. SYMPTOM/CONDITION: With a hot engine the oil pressure light may be on or flicker on at idle. DIAGNOSIS: Verify engine oil pressure as described on page 9-21 of the 1999 Concorde/Intrepid/LHS/300M service manual (Publication No. 81-270-9140). If engine oil pressure is within specification perform the Repair Procedure. PARTS REQUIRED: Qty Part No. Description 1 05017800AA Wire Terminal/Vent REPAIR PROCEDURE:
Thanks,
Dave
Old Oct 9, 2007 | 11:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: oil light comes on..
Replace the oil pressure switch and reck. If the litestill comes on then you will to hook up a pressure gauge.
Old Oct 24, 2007 | 11:30 AM
g00dy11's Avatar
g00dy11
I had the oil pressure light come on with a warm engine at idle on my 2001 Intrepid with a 2.7. I had just receintly done an oil change. I replaced the oil filter and had no more problems. It happened to me twice using Fram oil filters. Now I use Wix filters.
Old Oct 24, 2007 | 08:21 PM
TCPMeta's Avatar
TCPMeta
Use K&N or Purolator Pure1oil filters.
On the matter of the oil filter for the 3.2L and the 3.5L and maybe not sure for the 2.7L you can use the Purolator Pure1 PL30001 that is made for the mustang 5.0L motor from ford. The filter is bigger and helps to filter the oil better.
