2nd Gen Intrepid 1998 through 2004 Intrepids
2001 2.7L engine burning oil
Old Nov 1, 2007 | 01:12 AM
bucksaw87's Avatar
bucksaw87
Default 2001 2.7L engine burning oil
well, before i left for college last fall, i changed the oil and filter, PCV valve, air filter, and spark plugs...upon driving the 400ish miles to college, i checked the oil and noticed it was about a quart low...and since then, whenever i drive over 100 miles at a time, seems like the oil is lower after i get there. can i fix this somehow?
Old Nov 1, 2007 | 03:54 PM
bucksaw87's Avatar
bucksaw87
Default RE: 2001 2.7L engine burning oil
hmm? anybody?
Old Nov 1, 2007 | 04:34 PM
decimon's Avatar
decimon
If the problem wasn't there before the oil filter was changed then the oil filter should be the problem.
Old Nov 2, 2007 | 02:12 PM
kurts2's Avatar
kurts2
Or the drain plug is loose, check if there are external leaks around the filter and or drain plug.
Other than that, how many miles on the engine? What color is the exhaust? Are there evident oil leaks around the head? Do a compression test on all cylinders and record your findings. If low compression, then add about atbs of oil to each cyl (one at a time) and see if the compression changes. If so, rings are the problem. If not, the head gasket or head (valves) are at fault.
Old Nov 2, 2007 | 02:17 PM
bucksaw87's Avatar
bucksaw87
ORIGINAL: kurts2
there aren't any leaks around the filter or plug...when i take off from a stop, the exhaust is a little bit blue
but sometimes when i start the car up, it'll rev to like 2000 rpm for a second or two
Old Nov 2, 2007 | 02:41 PM
kurts2's Avatar
kurts2
How many miles? I'd press on with the compression test.
Old Nov 2, 2007 | 02:44 PM
bucksaw87's Avatar
bucksaw87
probably around 88-90k
