2nd Gen Intrepid 1998 through 2004 Intrepids
p1495 code (leak detection pump)
Old Nov 18, 2007 | 01:35 PM
albinoone's Avatar
albinoone
Default p1495 code (leak detection pump)
Fixed the tone ring as you told me and everything on the car works fine except I get a code 1495. The local Dodge dealer put the vin and mileage into the used computer I installed and I thought everything was O.K. but found out today the car was never wired to use the leak detection system from the factory (pulled back seat and the three wires are missing from the fuel pump wire connector. There are extra wires coming from the front but the pins have plugs in them). Can the dealer flash program the car and relearn that it didn't come with the LDP or do I need to find another computer? Would it be easier to remove the electrical pin plugs and run my own wiring to the pump or would that cause other EVAP system problems? It's the only code in the PCM but it still makes the service engine light stay on. Thank you
Old Dec 14, 2007 | 08:25 PM
albinoone's Avatar
albinoone
Default RE: p1495 code (leak detection pump)
Found the problem with the code 1495. Turns out I installed a California computer on a Federal car and the leak detection pump won't work cause it's not wired up. Got another used computer and it's fine now.
