2nd Gen Intrepid 1998 through 2004 Intrepids
HELP ME PLEASE
Old Jan 27, 2008 | 05:18 PM
IVEHADIT's Avatar
IVEHADIT
Default HELP ME PLEASE
I HAV A 2002 DODGE INTREPID 3.5 THE CHECK ENGINE LIGHT CAME ON ONE DAY AND I HAD IT SCANNED THE CODE WAS P0152 AND I BOUGHT A NEW O2 SENSOR PUT IT IN ANDCLEARED CODE THEN STARTED CAR WITHEND 10 MINUTES CHECK ENGINE LIGHT CAME ON SCANNED AGAINIT HAS THAT DAMM CODE P0152 WHAT AM I MISSING DOES ANYBODY NOW WHATS UP WHAT WOULD MAKE THE VOLTAGE HIGH
Old Jan 27, 2008 | 07:47 PM
bluesfool's Avatar
bluesfool
Default RE: HELP ME PLEASE
There are two sensors...did you replace both? One is on the exhaust manifold and the other is on the cat.
Old Jan 27, 2008 | 10:57 PM
IVEHADIT's Avatar
IVEHADIT
NO I JUST REPLACEDTHE FRONT RIGHT O2 SENSOR I DIDNT REPLACE THE OTHER 3 CAUSE THE SCANNER SAID THEIR GOOD NO PROBLEMS JUST THE 1 RIGHT FRONT HIGH VOLTAGE IS WHAT THE SCANNER SAYS THE ONE BEFORE THE CAT MY CARS HAS RIGHT AND LEFT O2 SENSORS BEFORE THE CATS AND TWO AFTER THE CATS
Old Jan 28, 2008 | 08:57 AM
bluesfool's Avatar
bluesfool
My only other idea is to double check the wiring and make sure it's not frayed/cut anywhere. Make sure the connector is clean too.
Old Jan 29, 2008 | 11:00 PM
holtzer1's Avatar
holtzer1
high voltage bank 2 sensor 1
bank 1 is the left side on intrepids.....which is why your still getting the code.
drivers side is the one you need to replace
