2nd Gen Intrepid 1998 through 2004 Intrepids
99 INTREPID ES Interior Lights
Old Jul 19, 2008 | 10:04 PM
Leslie J's Avatar
Leslie J
Default 99 INTREPID ES Interior Lights
Interior lights are not shutting off. (normally after 20 seconds or so they dim slowly and turn off)Experienced first timeabout a month ago and pulled the fuse (slot 19) and drove it a week or so. Replaced the fuse and magically lights operated properly. Today the gremlin returned. Pulled fuse drove briefly &replaced..no help. Fiddled with rotary light/dimmer switch ..no help. Suggestions? Thanks Les
Old Jul 20, 2008 | 04:49 PM
kurts2's Avatar
kurts2
Default RE: 99 INTREPID ES Interior Lights
I assume there is not a door ajar light and the indicator lamp is working (the door light comes on with a door open)...if so, either the dimmer switch or the BCM.
Old Jul 21, 2008 | 01:22 AM
Leslie J's Avatar
Leslie J
Thanks for the response. The Door Ajar indicators and lights are working properly. I'll try swapping out the dimmer switch (I have a spare). If its the BCM, can I do it myself with a Haynes manual, voltmeter, and 4 thumbs? Les
Old Jul 21, 2008 | 12:22 PM
kurts2's Avatar
kurts2
If you have the VTSS the BCM must be reset with a DRBIII tool ($6000 tool!) before you can start your engine. This makes the job dealer only
There are a few other things to check first:
1. Will the lights go out when you arm the alarm?
2. Will they go out after 15 min (with doors closed)?
Let me know
Old Jul 22, 2008 | 10:56 AM
kurts2's Avatar
kurts2
How many lights and which ones ore comming on (they are diffrent circuits...will help isolate if you have a wire prob).
PS I got your email, try posting again via forum, maybe they fixed the site.
Old Jul 22, 2008 | 11:16 AM
Leslie J's Avatar
Leslie J
KurtThe offending lights are the ones that normally go "On" when a door is opened or the Headlight Sw rotary dial is put in the "Dome" light position. 2 Map, 2 Courtesy (front), 2 Courtesy (rear).After closing a door, the Odometer light times out as it should, and "door ajar" light goesoff . The maddening thing is the problem occured a month ago and then disappeared after I pulled the fuse, and replaced it after a few days. Another tidbit.. since pulling the interior light bulbs , my remote control garage door opener seems to have the proper range. When thebulbs were"in" and "on" the range shrunk by 2/3.Les
Old Jul 22, 2008 | 12:00 PM
kurts2's Avatar
kurts2
Yup, it sounds lik the BCM. If you do not wish to fix it, I think I may have a work around. It involves a little re-wiring, and when done, the lights will come on when you open the driver door (only) and/or when you turn them on via the switch. It's a better option than no lights at all, but involves a little work and system modification. E-mail me if you want to know.
Kurt
