2nd Gen Intrepid 1998 through 2004 Intrepids
96 intrepid error code p1296
Old Sep 25, 2008 | 09:16 PM
dlw0427's Avatar
dlw0427
Default 96 intrepid error code p1296
I have a 96 intrepid with a 3.3. It is showing error code p1296. What does this mean?
Thanks
Old Sep 29, 2008 | 02:00 AM
kurts2's Avatar
kurts2
The 5 volts needed at the MAP sensor, are not present. Probably a broke wire, or loose connection.
Kurt
Old Oct 1, 2008 | 05:50 PM
manuel.feli's Avatar
manuel.feli
P1296 1T CCM 2000-04 300M, Concorde, Intrepid, LHS 5-Volt VREF Supply Not Present Conditions: Key on, altitude indicating zero feet above seal level, then the PCM detected the MAP Sensor was near 101 kPa; or with altitude at 1200 feet above sea level, the MAP Sensor was near 88 kPa. Possible Causes: MAP Sensor VREF circuit open between the Sensor and PCM MAP Sensor ground circuit open between the Sensor and PCM MAP Sensor is damaged or has failed PCM has failed
