2nd Gen Intrepid 1998 through 2004 Intrepids
forgot to remove neg from battery
Old Oct 9, 2008 | 10:28 AM
houndog's Avatar
houndog
Default forgot to remove neg from battery
2002 ES 3.5 I pulled a couple relays from the fuse & relay section and forgot to pull the neg cable. I have a tranny problem and was looking at some posts and some referred to the TCM relay. I switched a couple of the relays around to see if that was the problem..Now When I turn the key on I get nothing. What is the fix??...james
Old Oct 27, 2008 | 01:03 AM
mlkmgr's Avatar
mlkmgr
could have shorted the relays, but more than likely blew another fuse while flip flopping the relays. double check ALL fuses--under the hood and to left of the dash-- and verify nothing is blown. if possible, switch relays back to original location, could be a wrong relay in a location. good luck...
also, is the check engine light on?
