1998 Intrepid Speedometer Tachometer and Odometer
Hello I have a 1998 Intrepid and it has about 132K on it Speedometer Tachometer Odometer and interior lights stopped working at one time everything else seems fine with the car. I was told it could just be a fuse? Not even sure where to look can I get some real help??????
well first I would check the codes. Is the engine light on? Can you shift out of 2nd gear? if not its probably the output and input sensors same thing happen to my 99 ES, you can get the parts at any local shop and I had a shop replace mine since you kinda have to have good jack eqp. to get under the car.
As for the lights probably a fuse, check the engine bay and read the fuse box or the one inside the door panel not sure what one it is located in.
hey .... well it seems to be running fine it is an automatic so hard to tell but motor does not seem to be working too hard or anything just those things I mentioned I am going to take it to get the codes read sometime this week......and hopefully we will know more andyes the check engine light is on
