2nd Gen Intrepid 1998 through 2004 Intrepids
best seal for tranny pan
Old Aug 4, 2009 | 06:40 PM
BigBlocksnHardRock's Avatar
BigBlocksnHardRock
Default best seal for tranny pan
Is the gasket that is given with the filter best to use, or is there a sealer (like what was on it) best to use?
Old Aug 6, 2009 | 12:08 AM
swithrow's Avatar
swithrow
The gasket I used was a metal & rubber gasket (2.7) and I was told NOT to use sealant.
Old Aug 11, 2009 | 08:32 PM
DESIREESAVENGER's Avatar
DESIREESAVENGER
I use mopar ATF RTV and have had no problem. Just clean both surfaces well before you put it together and let it dry a couple minutes before you put the ATF in.
