2nd Gen Intrepid 1998 through 2004 Intrepids
My power steering is making loude noise?
Old Oct 1, 2009 | 06:01 PM
leeangelo's Avatar
leeangelo
Default My power steering is making loude noise?
Hello I'm having a big problem with my powersteering. Ever since I bought this car it made a louse noise while the car ran, and would get louder as I accelerate. I was told this is the powersteering pump and this happens when they go bad. Ok so I decided to have it replaced but now the noise is even louder and now when I turn my wheel it makes this very loud grinding noise as if the power steering pump is struggling. I thought maybe the new power steering pump was bad, so I had another one installed, and yet it still does the same thing. I don't know what to do, does anyone know the solution to this problem. Honestly my car is worse off than it was with the old power steering pump that was on it. I paid lex broady's to bleed the system and it did get a little more quite, but still very loud as it should not be. And after the car sat, and I started it l8ter, the car was as loud as it was before I had lex broady's do the flush and bleeding of the powersteering system. Thank you so much I really need your guys advice.
