2nd Gen Intrepid 1998 through 2004 Intrepids
starter on a 1998
Old Oct 12, 2009 | 07:58 PM
jeeper01ca's Avatar
jeeper01ca
Default starter on a 1998
what's the location of the starter on a 1998, 3.2L and which pin shall I connect to the ground to get it started?
Old Oct 12, 2009 | 09:01 PM
shelbydaytona's Avatar
shelbydaytona
u dont ground any pin on the starter that wont do no good. why do u want to jump the starter? u can do it at the relay in the underhood fuse block. and the starter is under the car on the left side
Old Oct 12, 2009 | 11:55 PM
jeeper01ca's Avatar
jeeper01ca
How do you do it?
Is that from the driver side?
Old Oct 13, 2009 | 06:30 AM
shelbydaytona
Originally Posted by jeeper01ca
How do you do it?
with a paper clip
on the left side, is there any other left?? have a look and u will see it
Old Oct 16, 2009 | 04:24 PM
DESIREESAVENGER's Avatar
DESIREESAVENGER
Take the cover off of the power distribution center. Remove the starter relay. Look at the diagram on the relay. Visualize which terminal on the relay corresponds to the openings left in the pdc when you removed the relay. Connect terminals 30 and 87a.
