2nd Gen Intrepid 1998 through 2004 Intrepids
runs sometimes
Old Oct 15, 2009 | 05:27 PM
impidemic's Avatar
impidemic
Default runs sometimes
2001 dodge interpid rebuild engine all new sensor new battery. When you drive for about 15 minutes just shuts down and will not restart, if I try to start it up later on in the day it will.
I also replaced the fuel pump. This car is giving me a hard time trying the figure it out can any one help me Please. thanks in advance
e-mail me if you have a answer impidemic@gmail.com
Old Oct 24, 2009 | 02:32 PM
dannyas's Avatar
dannyas
I had a problem like this with a dodge durango what I check the fuel pump voltage and it would go out some times and so I changed the fuel pump just in case because i wasn't getting fuel.... then I also noticed that i wasn't getting spark to the engine.... finally gave up and gave it to one of my guys and found out it was a couple things i sent the computer to be redone for 175 off ebay to florida to people that fix them... then the wiring harness to the computer was really loose check that out....
