2nd Gen Intrepid 1998 through 2004 Intrepids
2002 Dodge Intrepid Short Wiring Diagram Help...
Old Oct 24, 2009 | 02:08 PM
dannyas's Avatar
dannyas
Default 2002 Dodge Intrepid Short Wiring Diagram Help...
Ok So the car got in a wreck and shorted the battery... The alternator was burnt up.... I changed that got it running good now but the only problem now is over night the battery will lose charge.... It has a new battery....
Ok so I got a multimeter and found the car was pulling 14.97 ohms draw from the battery without the key in... So I started pulling fuses and relays I found 4 major ones that were drawing allot of ohms....
I 30 AMP STOP LAMPS
L 40 AMP PARK & HORN
N 30 AMP ASD
O 20 AMP HAZARD
If I pull those the Ohms goes down to 3.15... if I leave them out over night the battery holds it charge my guess is there is a short in the wires....
I guess I need a wiring diagram because I pulled the lights harnesses out of the back of the car no change....
Also It would help to know where they are going the relays and what should the ohms be....?
Old Oct 24, 2009 | 04:33 PM
dannyas's Avatar
dannyas
Ok so I'm tracking the shots down so the relay box is good I pulled all the connections out of all the things going out of it and its good.... so I ran the fuses on the inside of the car and found that
19 INTERIOR LAMPS
18 HORN AMP
7 ILLUM LAMPS PARK LAMPS
fuses have a short in them when I pull them I can get it down to like 7.5 ohms......
There is still another short after the ASD RELAY witch has something to do with the motor or auto shut off system.... I can get it down to like 3 ohms pulling the AMP ASD relay or pulling the far left wiring harness connection..... ANY HELP WITH DIAGRAMS PLEASE
Old Nov 28, 2009 | 11:12 PM
mouse23's Avatar
mouse23
You might find electrical diagrams following the Holy Grail link at the beginning of this Intrepid list.
