2nd Gen Intrepid 1998 through 2004 Intrepids
01 2.7 water pump replacement
Old Dec 2, 2009 | 04:09 PM
patrick882's Avatar
patrick882
Default 01 2.7 water pump replacement
anybody got a detailed instructions on how to replace the water pump on a 01 intrepid with 2.7 i cant finmd anything anywhere i need the procedure for getting the chain on and off without messing up the timing marks
Old Dec 2, 2009 | 08:56 PM
92dak5.24x4's Avatar
92dak5.24x4
I found tons of instructions on how to replace the timing chain in various service manual sources such as Factory service manuals, Shopkey5, Mitchell service books, etc. Word of warning, this job is s BEOTCH to say the least. One small error and your engine will be junk! You will need a special crank pulley puller. and be prepared for many hrs of frustration. However if you have enough beers, it's a bit more painless. A quick google search shows a lot of decent instructions http://www.google.com/search?hl=en&q...&aq=f&oq=&aqi=
Old Dec 3, 2009 | 12:16 AM
master tech's Avatar
master tech
Site Moderator & Tech
If you haven't done a water pump on a 2.7L. You may want to have a shop do the repairs. Because you may not have the special tools to do the repairs.
Old Dec 3, 2009 | 07:41 AM
patrick882's Avatar
patrick882
i have replaced many water pumps and timing belts before but i cant seem to find the marks where the chain is supposed to line up for it i have it apart righht nowand i see the arrows on the cam sprocket but where are they supposed to line up with..... the only special tool needed is a crank puller which i have that ii already have all that taken apart i just need to know how to get the engine at tdc with the marks lining up and get the chain off
Old Dec 3, 2009 | 12:02 PM
circumventor's Avatar
circumventor
i done a few 2.7s and its pritty hard as said. i recal that i had to line up diff colord links on teh chain with marks on the sprokets.
Old Dec 3, 2009 | 06:08 PM
patrick882's Avatar
patrick882
ok i got everything done and put back together but wehen i filled it up with antifreeze it started pouring out of the weep hole again and i havent even cranked the car up..... whats going on??? do i need to start it up first to get it to stop or what??
Old Dec 3, 2009 | 10:10 PM
92dak5.24x4
Either you have the same problem or you didn't assemble it correctly. No it just won't magically fix itself.
Old Dec 3, 2009 | 10:36 PM
patrick882's Avatar
patrick882
it was definitely assembled correctly and dont think i could get a bad pumpfrom chrysler im starting to lean towrds a head gasket or cracked head because the person whose car it is ran it hot enough to where it was sputtering and cutting out and i have cranked it see if it stops and it does but then it bubbles realbad into the resevoir adn then once it cools down it leaks out of the weep hole again
Old Dec 4, 2009 | 08:13 AM
circumventor
ya coud be hg, yall mite figgure that out with a leakdown test. of corse everyone with some prob alwys says that i forsure pit it toghether abslutely correct but if the gaske was not rite nicked or somthing or even some little dirt on the moter. sounds like a bumer cuz pulling the heads aint no fun ether. when i do them i'm carful not to undo the cam to cam timing. on one moter i couldnt find no marks to line up cam to cam the book says these have colored links like the main one but i couldnt find them on mine so i just was careful wen i pulled them off togethr
Old Jan 10, 2010 | 12:25 PM
deezozdodge's Avatar
deezozdodge
Couldve either purchased a defect or put the old water pump on, but I know you're that careful in not to. I had mine done by a mechanic, and so what I paid 800.00 for the job, but I paid for peace of mind - that is when I had the 800.00, then a different story.
