2nd Gen Intrepid 1998 through 2004 Intrepids
2003 intrepid prob with cruise control and engine starting
Old Jan 26, 2010 | 04:31 AM
tfujiwara8's Avatar
tfujiwara8
Default 2003 intrepid prob with cruise control and engine starting
Hi, is there anyone had encounter the same problem as me. The cruise control light comes on for like 5 seconds and go off and cant be used? Previously was after the car travelled for quite some time, cruise goes off by its own and would not come back on. Also the engine is unable to start normally after the car is going to be restarted in a jiffy after a quick stop. This will not happen if the car has completely cool down. Does the above scenarios point to a weak battery?
Old Jan 29, 2010 | 07:11 AM
deezozdodge's Avatar
deezozdodge
Check batter and starting system.
Old Feb 2, 2010 | 09:35 AM
blackskyracing's Avatar
blackskyracing
What does it do on a quick restart? Crank fine with no fire or crank slow?
Old Feb 3, 2010 | 07:14 AM
tfujiwara8's Avatar
tfujiwara8
it cranked fine with no fire.
Old Feb 3, 2010 | 03:25 PM
choirboyjr45@hotmail.com's Avatar
i had the PCM sent away for alot of problems like stalling and irregular acceleration but just check through the ignition system such as wiring, plugs, coils, etc. the coils will get some corrsion on it over time just take them out and then use a soft wire brush to clean them
Old Apr 4, 2010 | 10:29 PM
julezfontaine's Avatar
julezfontaine
Does it jump gears on road?
Old Apr 5, 2010 | 04:04 PM
tfujiwara8's Avatar
tfujiwara8
nope. it drives just fine
Old Apr 11, 2010 | 01:15 PM
well the cruise control module can be replaced also the clip that goes into it tend to get lose and fall off
