2nd Gen Intrepid 1998 through 2004 Intrepids
cheap performance chip is messing up my engine
Old Feb 3, 2010 | 03:45 PM
choirboyjr45@hotmail.com's Avatar
Exclamation cheap performance chip is messing up my engine
i have a 99 intrepid and i put these chips and so far ive only had 2 codes 1 cylinder 1 misfire and 2 o2 circuit no activity detected and after driving it today i have a gear 4 incorrect linking and transmission contol system(mil request) idk whats going on but i need to no what to do it wont go past second enless i stop get my OBD2 tool out and clear it then about 5-9 minutes into driving itll do it again i need help thanks heres the link to the chip PS DONT BUY IT!!!
http://www.engineperformancechip.com...nce-module-p-7
Old Feb 3, 2010 | 11:37 PM
lennemann23's Avatar
lennemann23
If I were you I would remove the chip/chips and reset the computer and go from there. It sounds like the chip is messing with the oxygen controls and the transmission controls.
Old Feb 5, 2010 | 07:13 PM
ya i took off the chip and i still have the transmission issues but i also cleared the light with my OB2 reader does that reset it or is there another way
Old Feb 6, 2010 | 07:35 PM
lennemann23
Not that I know of. All you should have to do it hit "clear codes" on your OBD2 tool. What exactly is the transmission doing?
Old Feb 8, 2010 | 11:09 PM
i have 3 codes one saying transmission control system (mil request) 2 other codes saying gear 3 and 4 have incorrect gear ratios i reset everything by taking out the battery connectors and holding them together for a minute then i put a quart of transmission fluid in because for a snow storm i found i have a minor leak around a gasket so then im going to change out the filter and gasket for a new one. but i havent driven it yet because im scared to but im selling it now for 2500 on craigslist
Old Feb 9, 2010 | 06:17 PM
kurts2's Avatar
kurts2
I don't think the tcm resets with a obdII tool. The bat trickc ( off for 10-15 min) should reset it or if you had a DRB tool.
Old Feb 10, 2010 | 08:55 PM
who can afford that lol and what do you mean by bat trick
Old Feb 11, 2010 | 12:04 AM
kurts2's Avatar
kurts2
Disconnect battery for 10-15 min
Old Feb 12, 2010 | 11:30 PM
thanks man ill do that
