2nd Gen Intrepid 1998 through 2004 Intrepids
Start Hesitation
Old May 9, 2005 | 04:46 PM
jasond1211's Avatar
jasond1211
Default Start Hesitation
99 2.7L 70,000 M . For the last few months I will try to start the car and nothiong will happen. Sometimes takes as long as five minutes for car to start sometimes starts right away. No starter clicks or nothing. Had battery and starter tested on intersate tester and everything was fine
Any info you be great
Old Aug 27, 2005 | 05:41 PM
hemipower1984's Avatar
hemipower1984
Default RE: Start Hesitation
check to see if positive battery cable is making a bad coonection pretty common for corrosion build up due to were battery is located in right side wheel well area.
