2nd Gen Intrepid 1998 through 2004 Intrepids
99 intrepid 2.7 oil light flickering
Old Jun 17, 2010 | 01:33 PM
pcolonna's Avatar
pcolonna
Default 99 intrepid 2.7 oil light flickering
The oil light flickers at idle when warm, I changed the oil pressure switch and added the recommended wire vent but it still flickers. The oil pressure test was good. Any ideas where to look??????????
Old Jun 17, 2010 | 01:43 PM
pcolonna's Avatar
pcolonna
Can anyone help me with this problem. I have tried everything.
Old Jun 19, 2010 | 09:04 AM
jonkrause123's Avatar
jonkrause123
Look if it is leaking oil from the oil pressure sensor. passenger side of engine from underneath the car it is towards the top. I dont believe you can see it from above
Old Jun 19, 2010 | 09:37 PM
pcolonna's Avatar
pcolonna
Default 99 intrepid oil light flickering
no oil leaks from the pressure switch or anywhere else. the light flickers ai warm idle at about 500 to 600 rpms goes off as you step on the gas
i installed the recommended wire vent but flickering light persists. oil pressure was tested and is good at idle. cant figure it out
Old Jun 21, 2010 | 12:20 AM
kurts2's Avatar
kurts2
How did you test it as good pressure?
Old Jun 21, 2010 | 12:26 AM
DodgeTech228's Avatar
DodgeTech228
What reading did you get @ idle with a mechanical gauge? In my experience with the 2.7, the oil pump/pickup is usually the culprit.
Old Jun 21, 2010 | 09:17 PM
pcolonna's Avatar
pcolonna
thanks Dodgetech228 when i have time i will drop the oil pan take out the pick up tube and clean it good. if that does not work do you recommend changing the pick up tube??
paul
Old Jun 23, 2010 | 09:52 PM
torsiondrummer's Avatar
torsiondrummer
I changed the oil fuel sensor, like it said in one of these posts- i got the flicker still for 3 weeks, and noticed the last week-nothing!
Old Jun 23, 2010 | 11:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
OIL PUMP
REMOVAL
The oil pump pressure relief valve can be serviced by removing the oil pan.
Refer to procedures in this section for removing the following components:
Crankshaft Damper
Timing Chain Cover
Timing Chain
Crankshaft Sprocket
Oil Pan
Remove oil pick-up tube and O-ring Oil Pump and Pick-up Tube
Ensure that crankshaft position is at 60° ATDC of No.1 cylinder, or crankshaft sprocket mark aligns with mark on oil pump Crankshaft Positioned At 60° ATDC No.1 Cylinder This position will properly locate oil pump upon installation.
Remove oil pump attaching bolts Oil Pump and Pick-up Tube
Remove oil pump
INSTALLATION
CAUTION: Crankshaft position must be at 60° ATDC of No.1 cylinder before installing oil pump Crankshaft Positioned At 60° ATDC No.1 Cylinder This position will properly locate oil pump. If not properly located, severe damage to oil pump can occur.
Prime oil pump before installation by filling rotor cavity with engine oil.
If crankshaft has been rotated, it must be repositioned to 60° ATDC of No.1 cylinder prior to oil pump installation Crankshaft Positioned At 60° ATDC No.1 Cylinder
Install oil pump carefully over crankshaft and into position.
Install oil pump attaching bolts. Tighten bolts to 28 N·m (250 in. lbs.) Oil Pump and Pick-up Tube
Install oil pick-up tube with new O-ring. Lubricate O-ring before installation. Tighten attaching bolts to 28 N·m (250 in. lbs.) Oil Pump and Pick-up Tube
Install the following remaining components following procedures in this section:
Oil Pan
Crankshaft Sprocket
Timing Chain
Timing Chain Cover
Crankshaft Damper
Fill Crankcase with proper engine oil to correct level.
