2nd Gen Intrepid 1998 through 2004 Intrepids
Where is the plugs on the Intrepid 3.2?
Old May 15, 2005 | 11:18 PM
teddeath2000's Avatar
teddeath2000
Default Where is the plugs on the Intrepid 3.2?
Need to change the plugs and wires but ... I cant find them ??
Old May 26, 2005 | 08:01 PM
Neon Lights's Avatar
Neon Lights
Default RE: Where is the plugs on the Intrepid 3.2?
i think that the 3.2 is a coil on, or over plug system. were you able to get wires for that engine? i just saw one yeterday in a car that we picked up. every plug has it own coil. but like i sad i just saw it yesterday, so i donk now much about it
Old May 26, 2005 | 10:30 PM
zeekxxx's Avatar
zeekxxx
Very true - There are no wires. You get a coil on each plug. I changed out the plugs in my 2000 intrepid last year and you have to unbolt each little black box and under it you see the plug...
This was one of the ways they give you better fuel economy and more HP.
Old Mar 7, 2006 | 02:52 PM
shnormo's Avatar
shnormo
Use Iriduim Plugs, but yes the black coils are each held in by two screws. once the screws are off, discconect the power to it and pull up. You will have access striaght down to the spark plugs.
