2nd Gen Intrepid 1998 through 2004 Intrepids
2003 Intrepid ABS Module
Old Jul 28, 2010 | 11:48 AM
SenorRight's Avatar
SenorRight
Question 2003 Intrepid ABS Module
My intrepid ABS light has been on since late April (about 3 months), but sometime when I start the car, the light doesnt come on and I feel a grinding/pumping feeling when I brake at low speeds until the light does come on then it brakes normally. Also, sometimes has the brake light come on with it.
Information I've gathered says I'll probably need an ABS Control Module, but I was wondering if anybody knows where it is located in the car? a picture/diagram would be great. Will this probably cure the brake light? (brake light rarely comes on, but always the ABS)
Also, is there a quick fix until I can get the part? Fuse I can pull so the light remains on and the grinding/pumping stops?
Thanks in advance
Old Jul 28, 2010 | 01:03 PM
sapporo's Avatar
sapporo
the best thing to do is get a real scanner and see what is happening.
Old Aug 12, 2010 | 08:33 PM
DESIREESAVENGER's Avatar
DESIREESAVENGER
I agree you need to read the codes before you spend any $. I would be looking real closely at the tone rings for a break or chipped tooth.
