map sensor problems
hello i have a dodge intrepid 2000 engine 2.7.. n i think am having map issues like my car rpm sometimes drop too low it doesnt die .... n i always have this problem when i start my car in the mornings or when the engine is cold i get a hard starting .. i think that can be the crankshaft sensor ... id change the camshaft...
they told me the crankshafts symptoms are
cut off after a few minutes
unable to start at all
engine backfire or irregular rpm function
i need to know if i am on the right track .... my other question where is the crankshaft located is it hard to remove???
ok scanner scanner i dont have a damn code the only code i had wha the cat code 420....
"well m8s the shop GET IN GEAR told it was not my cat .. he test everything n it was my front oxygen sensor ..... "
So you are from Portrigal
So if you took it to a shop, then you got it scanned
Deixar de ser tão estúpido!
I think your problem is elsewhere. I would look into a sticking yhfhggh. It could also be a bad gfgjgfgh. That's about all the help I can give you though. It is hard to diganose a malfunction over the Internet and I think the shop may be able to help better.
He already took it to a shop to prove me wrong about the cat issue. so I guess from here out we should be racists and help him with other issues.
Trending Topics
wel yeah the other m8 did help me he told me was the oxygen sensor with the symptoms i got ... n you kept telling me it is you cat cat cat n it was not the damn cat ..you should be a school teacher soo yuo can help me with the spelling .. since you cant help with car issues... lol get a damn life pendejo
ooo ok soo this forum is to chill n waste our time????? itrepidspider1999 he help me alot n he was rigth what my problem was.... n you did help tooo .. if we have symptoms we can get an advise... bro
