2nd Gen Intrepid 1998 through 2004 Intrepids
low idle help please
Old Aug 6, 2010 | 06:56 PM
intrepid88's Avatar
intrepid88
Default low idle help please
members i have a dodge intrepid 2000 engine 2.7. with the low idle issue . no check engine light!!!!!! am guessing is vacuum leak or a bad map sensor not reading right.. \
car symptoms are
cold start when engine is cold
low idle the idle is between 1-0 rpm
Old Aug 6, 2010 | 10:36 PM
intrepid88's Avatar
intrepid88
guys to day i check the map sensor n it had oil ???? is this bad or is normal????/ help me out guys plz
Old Aug 7, 2010 | 10:59 AM
kurts2's Avatar
kurts2
Check your compression. The idle should be between 0-1k so I'm assuming yours stalls at low idle.
Old Aug 7, 2010 | 12:50 PM
intrepid88's Avatar
intrepid88
compression is good.. yeah my idle is between 0-1 so are you saying my idle is all right?
why the map sensor was cover with oil ??? is that normal????
Old Aug 12, 2010 | 08:25 PM
DESIREESAVENGER's Avatar
DESIREESAVENGER
I'm curious. Why would you check compression for a low idle condition? The idle speed is controlled by the pcm via the iac motor. I've been a master chrysler tech for 25 years and am wondering what I have been missing.
Old Aug 13, 2010 | 01:06 AM
kurts2's Avatar
kurts2
Because his post sounds more like a "runs poor at low idle" not so much a low idle issue. Anyway hard cold start is not a low idle. Might be fuel, vac, timing, comp, stuck egr etc.
Old Aug 13, 2010 | 04:48 AM
sapporo's Avatar
sapporo
I bet that some people just like to make up stuff because they have no friends then when they p.o enough people they change their id and start over with more goofy problems or non-problems. right m8?
Old Aug 13, 2010 | 08:13 AM
kurts2's Avatar
kurts2
Why bother and waste time, life is too short.
Old Oct 12, 2010 | 11:36 PM
Intrepidspeeder1999's Avatar
Intrepidspeeder1999
car symptoms are
I had the same problem with my car, what I did was I replaced
the IAC, my car starts up with no problem at all and the low Idle
is no longer low no more since I replaced the IAC,
it was not the the Map sensor..
Also its normal to have oil on the Map sensor.
