crank sensor problem
i was working on my car checking oil level ect . and i look at the crank sensor is next to the trans .. while i was looking i saw the two cables from the conector had gray tape. soo i turn the eengine on. n i start moving the crankshaft sensor conecctor n the engine shuts off .. well it runs back agian but thats wierd. am also having revolution problems .. n no check engine light are this signs of crank sensor falling???
updated
the car still runs. but i have problem with the rpm revolutions.. the problem is when i move the crank connector the engine stall n shuts off..
updated
