2nd Gen Intrepid 1998 through 2004 Intrepids
2002 intrepid wont stay running
Old Jan 3, 2011 | 12:06 PM
TOPGLOCK's Avatar
TOPGLOCK
Exclamation 2002 intrepid wont stay running
2002 intrepid after it warms up it wont idle. You will come to a stop sign or stop light and as soon as you take your foot off the gas it stalls. Now you can put it back in park and it will start right back up but it idles rough. We replaced the IAC with no change. Any ideas?
It does idle smooth when you first start it before its warm
Old Mar 18, 2011 | 02:02 AM
santav's Avatar
santav
my 03 intrepid seems to be having a similar problem. after about 20 minutes of driving, the car started jerking (like some misfiring) the rpm is unstable. the car would stall when it comes to a halt but could easily restart when put into "P". sometimes, i would use my left leg for braking while keeping my right on the gas pedal to maintain a higher rpm.
any help appreciated.
Old Mar 18, 2011 | 08:53 AM
22DODGE22's Avatar
22DODGE22
I wonder if it's an EGR related issue or a vacuum leak??
Old Mar 20, 2011 | 11:24 AM
kurts2's Avatar
kurts2
Id look yo the egr
Old Mar 22, 2011 | 08:44 PM
santav's Avatar
santav
pardon my ignorance, what is EGR???
Old Mar 22, 2011 | 10:29 PM
'87IROCZOWNER's Avatar
'87IROCZOWNER
Exhaust gas recirculation, ok if you sit in yourcar the cylinder head to your right if you are in front of your car its to the left take your hand and feel on the back of that head its down toward the bottom you can also follow the pipes from the plumuam
Old Mar 23, 2011 | 12:08 AM
kurts2's Avatar
kurts2
Its an emissions system. Exhaust Gas Recirculation. It routs some of your exhaust back into the air intake to reburn unburned gas. It only should come on when the engine is warm and at higher toms. If it sticks, as the toms drop, the engine can stall due to a lack of O2.
Old Mar 23, 2011 | 12:10 AM
kurts2's Avatar
kurts2
Darn phone! Not toms, RPM's.
Old Mar 23, 2011 | 09:14 AM
22DODGE22's Avatar
22DODGE22
What's a plumuam?
Old Mar 23, 2011 | 09:30 AM
kurts2's Avatar
kurts2
I think he ment plenum.
