2000 intrepid
I have a 2000 intrepid 2.7 motor went bad and i changed it with a motor i purchased and heard run. Before old motor went bad it would not start and when it did it didnt run right. I still have same problem with new motor. Number one cyl only fires and number 1 and 5 and 2 and 6 injectors fire. Checked injectors with snoyd light. This only happens when i unplug cam sensor crank engine then plug cam sensor back in and crank . I have replaced engine harness cam sensor crank sensor and computer with parts off my other 2000 intrepid. same thing happens. no bus com comes up as code in computer. this problem occured before i replaced the engine. All parts were installed on other intrepid and the car ran fine. I am needing help with this problem as i am not having any luck. I would like to get a wiring diagram for engine control and bus communication/
Here is a link to a service man. you will find what you need here .
https://dodgeforum.com/forum/2nd-gen...oly-grail.html
