2nd Gen Intrepid 1998 through 2004 Intrepids
P0700 and P0888 Codes
Old Feb 12, 2011 | 02:03 PM
Panfailure's Avatar
Panfailure
Default P0700 and P0888 Codes
Did a search but nothing for a P0888 code.
P0888 TCM Power Relay Sense Circuit
2004 Dodge Intrepid
Everything was fine just changed battery and now stuck in 2nd gear have reverse but that's it. Would appreciate any help/suggestions. I assume it's 2nd gear as it will run 50 mph at 4000 rpms.
Thanks, Jeff
Old Feb 12, 2011 | 02:08 PM
22DODGE22's Avatar
22DODGE22
I suggest you get a shop manual, a scanner, a DVOM and start there. Trying to figure out what is wrong with out these tools is pretty much impossible. Could be anything from a bad relay to a broken wire to a fried computer or a blown fuse. Hopefully when you changed the battery, you didn't accidently reverse polarity even for split second.
Old Feb 12, 2011 | 04:57 PM
Panfailure's Avatar
Panfailure
Problem solved and lesson learned. Never ever take your car to Wal Mart for a battery change. They put them fiber washers under the battery terminals and the terminals would not seat. Both cables were loose. Took washers out and terminals tightened up and shifts like a champ.
Thanks for everyone looking in!
Jeff
