2nd Gen Intrepid 1998 through 2004 Intrepids
Horsepower Gain
Old Jul 2, 2005 | 04:31 AM
nickoman01's Avatar
nickoman01
The Only Elite DF Member
Default Horsepower Gain
how much horsepower will i gain if i disconnect the air conditioning system. the evaporator is f*cked, so as far as I'm concerned my air conditioning system is dead to me. from what i understand, if i disconnect the A/C system, i will gain horsepower. for my intrepid, all i have to do is remove a belt, and the crank shaft is no longer connected to the A/C compressor.
Old Jul 2, 2005 | 04:35 AM
Saint's Avatar
Saint
Default RE: Horsepower Gain
When the A/C is not turned on there is minimum hp loss. The main benefit to removing the A/C system is the weight loss, not the gain in horsepower.
Old Jul 2, 2005 | 05:05 AM
nickoman01's Avatar
nickoman01
ORIGINAL: Saint
how much weight would i loss?
Old Jul 2, 2005 | 10:33 AM
Vader's Avatar
Vader
The compressor does not weigh too much probably 10 pounds. If you can remove it an find a shorter belt to drive your pullies, you might see a small gain.
Old Jul 2, 2005 | 02:49 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
it isnt a matter of it being on, or so much the weight.
you remove the compressor because even when not engaged, the drive belt is still turning the pulley on the compressor, and when it is turning ANYTHING, it creates a drag on the engine, since it is also powered by the crank pulley. this is the same reason that the mirada doesnt have power steering. the fewer things driven by the crank, the less parasitic loss is created, thus more power. i have seen a kid in a civic cut the drivebelt off on a track car and run with no powersteering, no ac, no alt, and no water pump before...
Old Jul 2, 2005 | 04:08 PM
ramfan5.9's Avatar
ramfan5.9
how much faster did it run?
i thought u needed a water pump lol
Old Jul 2, 2005 | 05:27 PM
Saint's Avatar
Saint
For a quarter mile run you really don't need a cooling system, look at most purpose built drag vehicles they have no cooling system at all.
Old Jul 2, 2005 | 06:26 PM
nickoman01's Avatar
nickoman01
ORIGINAL: BadStratRT
thats what i thought. on my 2.7 there are 2 belts, one doing the crankshaft, a/c, and a tensioner. the other doing everything else including the crank shaft. all i have to do is remove that first belt. i didn't think the a/c system weighted that much anyways
Old Jul 2, 2005 | 06:37 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
are you certain that the AC belt doesnt run the water pump as well? i am nto familiar with your engine...
Biopulse's Avatar
Biopulse
You can always add stickers! Good horsepower gains (dyno tested) and lightweight! Flames I hear are the best.
*cough*
