2nd Gen Intrepid 1998 through 2004 Intrepids
2002 Intrepid 2.7L Rebuild
Old May 2, 2011 | 12:43 PM
Danny in CO's Avatar
Danny in CO
Default 2002 Intrepid 2.7L Rebuild
I have a 2002 Intrepid with the 2.7L engine that I am rebuilding. It had a spuns rod bearing. I have had the crank turned and am now ready to put it back together. I need to know the torque specs for:
1. Main bearing caps
2. Rod bearing caps
3. Head bolts (I suspect that it is tighten to some spec and then tighten in steps)
4. Intake manifold
5. Exhaust manifold (I believe these are 17 ft/lbs.)
Thanks in advance!
