2nd Gen Intrepid 1998 through 2004 Intrepids
catalytic convertor
Old Aug 15, 2011 | 02:51 PM
placidone555's Avatar
placidone555
Default catalytic convertor
will my 2000 dodge intrepid run without a catalytic convertor - no emissions testing in my state
Old Aug 17, 2011 | 12:35 PM
misfitdakota_95's Avatar
misfitdakota_95
yes it will run w/o the cats, but your check engine light will come with a P0421 and/or P0431 code saying that the cats are ineffiecient/not working.
Old Aug 18, 2011 | 12:27 PM
placidone555
is there any way, that you know of, where i can eliminate the CAT and trick the computer where i won't get a light or code
Old Aug 20, 2011 | 11:40 PM
misfitdakota_95
it is very hard to do that, you have to know someone who can hack into the factory PCM programming and have them tell the PCM to ignore the downstream O2 sensor voltage. Other than that, it's illegal.
Old Aug 21, 2011 | 01:32 PM
placidone555
Thank you tery much for the info
