2nd Gen Intrepid 1998 through 2004 Intrepids
2000 chrysler intrepid won,t shift or hard into park
Old Dec 16, 2011 | 08:49 AM
marco huard's Avatar
marco huard
Default 2000 chrysler intrepid won,t shift or hard into park
bought car sometimes shift into park and sometimes not
what can be the issue
Old Dec 16, 2011 | 09:24 PM
steak59's Avatar
steak59
Check Shifter Cable for binding, might need some adjustment and lubrication on the Transmission linkage.
Or it is possible that you have a bad Floor shifter.
open it up and inspect it. Remove the Cable from floor shifter, see if you can slide the shift lever into Park, so u know if the problem is the trans side or the inside
I HIGHLY doubt there are internal trans problem.
Old Dec 17, 2011 | 09:16 AM
marco huard
thank u so much i bought the car and this is 2nd motor they put in previous owners i do have another shifter cable i,ll change that
