2nd Gen Intrepid 1998 through 2004 Intrepids
Help!!! install go wrong.
Old Feb 14, 2012 | 12:03 PM
Pcarrier0927's Avatar
Pcarrier0927
Default Help!!! install go wrong.
Hi all.
So a few days ago I doing an cd player install on my 2001 intrepid.
well it all went wrong when I tried to wire the orange to the ignition etc.
that didnt work so I read you could wire it to the fuse box.
I did wire to the fuse box when I heard the car give a weird screeching noise the lights came on and all of sudden it was like the car died.
I took the constant off the fuse box and put everything back togeather.
old stereo back in, everything back in place. I also checked every single fuse on my drivers side and under the hood, all fuses are good to go.
I go to start the car, and all the lights work 100% doesnt seem like the battery is dead what so ever. but the car wont even crank over.
So i jumped it. It would start with the negative terminal on the jump wire so I jumped then negative with metal. I took it for a drive thinking it would give the alternator and battery juice. I turned it off at home and still nothing wont even crank.
I took the battery out, brought it to auto zone and its a 100% percent and the alternator is good seeing its still giving the battery juice.
If anyone could help me what so ever that would be greatly appreciated seeing money is not on my side right now : (
Thanks alot hopefully talk to you soon!
