02 intrepid coolant bleeder housing
I am going to do this next weekend but i have a few questions.
1. Is draing the system though the lower radiator on the radiator the best way, it looks to be the easst to access
2. when reinstalling the plantum and installing the new plantum gaskets is there a trick to getting the plantum lined up with all those gaskets?
3. the bleeder housing repplacement seam straight forward 4 bolts two gaskets, almost to simple.
4. How best Do i flush the system
5. Are there any tricks that might help me
Thank you for your help
Pretty easy task to perform. No gaskets other than the small gaskets to the ports on the bleeder housing. There is a bleeder screw located on the right side (passenger) on the bottom right radiator. Open it but don't open too much. Have pan to catch Anti-freeze. You should be fine.
