2nd Gen Intrepid 1998 through 2004 Intrepids
1999 Intrepid 2.7L misfire issue
Old Sep 23, 2012 | 04:34 PM
jay467's Avatar
jay467
Default 1999 Intrepid 2.7L misfire issue
Hi, I've been spending months now researching ways to solve a problem with my Intrepid misfiring and lurching down the road. I have replaced all plugs and ignition coils already, and have replaced the intake manifold due to a vacuum leak. However, the issue still exists. The car runs horribly and struggles to accelerate. The check engine light was on and last I checked with a code reader it is saying I have an issue with something along the lines of coil B circuit primary/secondary. I cannot remember the exact code and had since deleted the codes in the hopes of having a new code appear (it hasn't yet). Does anyone have any clue as to what my next step should be with this car? Could it be a fuel injector? Or something else? Thanks for reading/helping out!
Old Oct 8, 2012 | 10:23 AM
Cblanning22's Avatar
Cblanning22
I just fixed this same problem with my 2004 Intrepid 2.7L. I just replaced the map sensor, about $88 for your year intrepid and now its driving perfectly
The MAP sensor mounts to the driver side of the intake manifold plenum.
The MAP serves as a PCM input, using a silicon based sensing unit, to provide data on the manifold vacuum that draws the air/fuel mixture into the combustion chamber. The PCM requires this information to determine injector pulse width and spark advance. When MAP equals Barometric pressure, the pulse width will be at maximum.
Also like the cam and crank sensors, a 5-volt reference is supplied from the PCM and returns a voltage signal to the PCM that reflects manifold pressure. The zero pressure reading is 0.5 volts and full scale is 4.5 volts. For a pressure swing of 0 - 15 psi the voltage changes 4.0 volts. The sensor is supplied a regulated 4.8 - 5.1 volts to operate the sensor. Like the cam and crank sensors ground is provided through the sensor return circuit.
The MAP sensor input is the number one contributor to pulse width. The most important function of the MAP sensor is to determine barometric pressure. The PCM needs to know if the vehicle is at sea level or is it in Denver at 5000 feet above sea level, because the air density changes with altitude. It will also help to correct for varying weather conditions. If a hurricane was coming through the pressure would be very, very low or there could be a real fair weather, high-pressure area. This is important because as air pressure changes the barometric pressure changes. Barometric pressure and altitude have a direct inverse correlation, as altitude goes up barometric goes down. The first thing that happens as the key is rolled on, before reaching the crank position, the PCM powers up, comes around and looks at the MAP voltage, and based upon the voltage it sees, it knows the current barometric pressure relative to altitude. Once the engine starts, the PCM looks at the voltage again, continuously every 12 milliseconds, and compares the current voltage to what it was at key on. The difference between current and what it was at key on is manifold vacuum.
During key ON (engine not running) the sensor reads (updates) barometric pressure. A normal range can be obtained by monitoring known good sensor in you work area.
As the altitude increases the air becomes thinner (less oxygen). If a vehicle is started and driven to a very different altitude than where it was at key ON, the barometric pressure needs to be updated. Any time the PCM sees Wide Open throttle, based upon TPS angle and RPM it will update barometric pressure in the MAP memory cell. With periodic updates, the PCM can make its calculations more effectively. The PCM uses the MAP sensor to aid in calculating the following:
Barometric pressure
Engine load
Manifold pressure
Injector pulse-width
Spark-advance programs
Shift-point strategies (F4AC1 transmissions only, via the CCD bus)
Idle speed
Decel fuel shutoff
The MAP sensor signal is provided from a single piezo-resistive element located in the center of a diaphragm. The element and diaphragm are both made of silicone. As the pressures changes the diaphragm moves causing the element to deflect which stresses the silicone. When silicone is exposed to stress its resistance changes. As manifold vacuum increases, the MAP sensor input voltage decreases proportionally. The sensor also contains electronics that condition the signal and provide temperature compensation.
The PCM recognizes a decrease in manifold pressure by monitoring a decrease in voltage from the reading stored in the barometric pressure memory cell. The MAP sensor is a linear sensor; as pressure changes, voltage changes proportionately. The range of voltage output from the sensor is usually between 4.6 volts at sea level to as low as 0.3 volts at 26 in. Hg. Barometric pressure is the pressure exerted by the atmosphere upon an object. At sea level on a standard day, no storm, barometric pressure is 29.92 in. Hg. For every 100 feet of altitude the barometric pressure drops 10 in. Hg. If a storm goes through it can either add, high-pressure, or decrease, low pressure, from what should be present for that altitude. Always know the average pressure and corresponding barometric pressure is for your area. The MAP sensor mounts to the driver side of the intake manifold plenum.
Removal & Installation
Remove the negative battery cable.
Disconnect the electrical connector from the MAP sensor.
Remove bolts from sensor.
Remove sensor.
To install:
Bolt sensor to intake.
Attach electrical connector to sensor.
Install the negative battery cable.
