2nd Gen Intrepid 1998 through 2004 Intrepids
Bad??? program or am i missing something!!!
Old Aug 17, 2013 | 05:19 PM
Stikk's Avatar
Stikk
Default Bad??? program or am i missing something!!!
Heys fellas got a 99 intrepid. Got a trouble of 0204 and 0304. Ok so i replaced the injector and plug in the #4 cylinder and reset dtc's. So now i get a 0204 only.
Here's what iv'e done so far
replaced injector
replaced spark plug
checked voltage at the injector plug. reads 13.76v running motor
visual on the wires looks good no bad spots and or pinches
Brand new PCM from dodge dealer programmed
Now it didnt have this problem before the PCM in stall the worksheet said PCM replaced, programmed, and car ran. and they said oh btw you have a check engine light on.
not sure what to do next
any help input is greatly appreciated thank you .....Michael
Old Aug 17, 2013 | 05:20 PM
Stikk's Avatar
Stikk
oh by the way its a 3.2 sorry
Old Aug 17, 2013 | 06:50 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Who told you that you should replace the PCM?
If it's just ONE injector setting a code, it's specific to that circuit. You only have ASD supply which is the power, and ground side which is PCM controlled.
I've seen wires broken INSIDE the insulation close to the terminals on many, many different things. Will drive the average person nuts throwing parts at it.
Old Aug 17, 2013 | 07:41 PM
Stikk's Avatar
Stikk
the pcm was replaced due to the car not start before and after the pcm install is when i got the 0204 code
what wire to check cause i tested the wire and it showed 13.76v while running.... how do i check the ground side and what wire on the main plug is the terminal
