2nd Gen Intrepid 1998 through 2004 Intrepids
2001 Intrepid EVAP solenoid wiring diagram
Old Aug 14, 2016 | 04:57 PM
biggman100's Avatar
biggman100
Default 2001 Intrepid EVAP solenoid wiring diagram
I am looking for the wiring diagram for a 2001 Intrepid, 2.7, auto, EVAP system. I get a code p0443, but upon further diagnosis, and using another running, good car to test parts, i believe the issue may be in the wiring harness. While i was testing the system, i did find that the 15 amp ignition fuse was blown. I fixed that, but, i only get 2.4 volts with the key on to the EVAP solenoid, and, i am assuming it is supposed to have either 5 or 12 volts with the key on. There isn't much information anywhere about this one issue, and the repair manuals i have looked at seem to mostly overlook it.
