2nd Gen Intrepid 1998 through 2004 Intrepids
'01 Intrepdid No Speedometer/Fuel gauge/Transmission not Shifting
Old Jul 17, 2017 | 12:46 PM
Ravyv's Avatar
Ravyv
Default '01 Intrepdid No Speedometer/Fuel gauge/Transmission not Shifting
I have a 2001 Dodge Intrepid that I am trying to fix and I'm not sure where to go
Problems:
Instrument Cluster - Speedometer not working, Fuel gauge incorrect, Can't see which gear I am in, and Mileage tracker not changing. Every once in a while I will get a No BUS message and all of the warning lights will light up
Transmission Won't shift past 2nd gear
Flashers and Hazards won't Turn On. I don't here the flick that is usually created when you try to turn them on.
Sometimes the car will shut off as I'm braking.
I have Checked the fuses (None of them are blown). I have changed the flasher switch (flashers still don't work) I have put in a new PCM, and I have changed the Spark Plugs. I have checked all of the bulbs (just in case there was a short), they are all fine.
Each of these issues have developed progressively. And I'm not sure where to look next
Any help or suggestions would be greatly appreciated!
Old Jul 19, 2017 | 10:33 AM
Hos old is the battery?
