2nd Gen Intrepid 1998 through 2004 Intrepids
Cold start problem
Old Sep 6, 2017 | 03:51 PM
owner.of.98.intrepid.es's Avatar
Default Cold start problem
Starting it, after sitting over night it'll spits and spudders for 3 to 4 minutes. At that point, it smoothes out and runs fine the rest of the day. I've had P codes check, first one was '1684' camshaft sensor, I replaced it, no change. Next, comes '0300' misfire code 5 out 6 plugs, replaced plugs, no change.
I looked up tons of info on these problems and one website or video said it could be a fuel line pressure leak. I heard a simple test to check for a leak. What I was told to do, with the first start, turn the key to on position, but don't start it. Leave the key on for 3 or 4 minutes, I tried it. The idea behind this is it gives the fuel pump time to get fuel to the injectors After waiting those few minutes, I started the car. It spits and spudders for the same 3 or 4 minutes as a cold start. Leads me to believe it might not be the fuel line pressure problem.
If anyone has an idea let me know.
Thank you, Kelley
1998 Dodge Intrepid ES 3.2L V6 109150 miles
