2nd Gen Intrepid 1998 through 2004 Intrepids
intrepid 2000 hiccup at low rpm (under 500)
Old Jan 9, 2018 | 11:05 PM
zztop777's Avatar
zztop777
Default intrepid 2000 hiccup at low rpm (under 500)
hello
when I stop at a red light or a stop
the engine gives a shot as if he wanted to stop
only when the rpm is under 500. but the engine does not stop
just like a hiccups
But it does not do it all the time
the problem is difficult to reproduce
there is no alarm.
is this someone already had this problem
Old Jan 10, 2018 | 07:17 AM
Either the IAC, TPS or a dirty throttle body.
Old Jan 10, 2018 | 03:01 PM
zztop777's Avatar
zztop777
Thanks JKAETON you for your response ultra-quick
I have this problem since exactly 9 months after a change of spark plug
and of the ignition coil.
is what the change of these two parts may have a link with my problem
thanks
Old Jan 10, 2018 | 03:06 PM
Is your check engine light on or have you had the vehicle scanned for stored codes?
Old Jan 10, 2018 | 03:09 PM
zztop777's Avatar
zztop777
Yes it has been scanned
No Error No Code
nothing
Old Jan 10, 2018 | 03:11 PM
I would also inspect your plugs and coils. Check for vacuum leaks.
Old Jan 10, 2018 | 03:19 PM
zztop777's Avatar
zztop777
yes there was error code
just before they change the spark plug
the Automobile was no longer advancing.
they have to change the spark plug (6)
and the ignition coil and also fuse
and since that time
I have problems like hiccups under 500 rpm
thanks
Old Jan 17, 2018 | 05:10 PM
zztop777's Avatar
zztop777
the mechanics have to change these two pieces
tps and IAC and the problem is still there
do you have any other solution to suggest me
