2nd Gen Intrepid 1998 through 2004 Intrepids
01 Intrepid
Old Nov 29, 2005 | 06:56 PM
Natedogg77's Avatar
Natedogg77
Default 01 Intrepid
I have a 01 Intrepid with 23,000 miles on it. It just got cold hear in Michigan and my fan for the heat only works on number 4. When I *** to 3 it completely shuts off because I can hear the ducs close. Has anyone had the same problem ???
Old Nov 30, 2005 | 11:29 AM
Houstonderk's Avatar
Houstonderk
Default RE: 01 Intrepid
Usually when the blower only works on high is when the resistor is messed up by the bloer motor. It has a default to high for foggy windows.
Old Nov 30, 2005 | 07:06 PM
Natedogg77's Avatar
Natedogg77
So I need to replace the resistor ?
Old Dec 2, 2005 | 11:26 AM
Houstonderk
yes. If it keeps blowing then usually the blower motor is using to much amperage and needs to be replaced also.
