2nd Gen Intrepid 1998 through 2004 Intrepids
Timing issue
Old May 12, 2020 | 11:15 AM
Therigwelder's Avatar
Therigwelder
Default Timing issue
I just bought an 01 intrepid 3.5.i got it cheap cause it’s not running.initially I thought it would be an easy fix since it had a camshaft sensor code. The new sensor did not fix the no start condition. Upon pulling the timing cover I found the tensioner broken off,the belt was loose but I damaged. How do I get the cams to line up with the pointers? Do I simply just line the pointers up and put everything back together,I do not know the position of the valves
Old May 12, 2020 | 11:20 AM
Welcome to DF! Moving this to the Intrepid section. I do not have an answer for you.
