2nd Gen Intrepid 1998 through 2004 Intrepids
1998 Intrepid fuel gage going crazy
Old Apr 20, 2006 | 12:40 AM
tristatedodgeboy's Avatar
tristatedodgeboy
Default 1998 Intrepid fuel gage going crazy
Help, my fuel gage is going to full then to empty dinging then going to full
and back to empty again. it is not always rythmic but it is steady. is it
the sending unit or is it something in the dash? has anyone ever had this problem or heard of it?
where should I start to look.
thanks
Andy
Old Sep 2, 2007 | 07:06 PM
cgator's Avatar
cgator
Default RE: 1998 Intrepid fuel gage going crazy
i have this same problem in my 01 es and would love to know the same while i still have my warranty...thank you in advance
Old Sep 2, 2007 | 07:08 PM
cgator's Avatar
cgator
it does not do it as much when the tank is full...though
Old Sep 4, 2007 | 04:56 PM
musicmind's Avatar
musicmind
My 2000 used to do this alot. I put in fuel system cleaner over the next 4 or5 fill-ups and that took care of the problem.
Old Sep 5, 2007 | 07:44 PM
tpsrt's Avatar
tpsrt
it could be your fuel level sensor, (sending unit) what ever you want to call it....its kind of a pain in the *** to do .....you have to drop the tank.....if i remember right you have to disconnect the rear sway bar and exhaust before you lower the tank.......the fuel level sensor is part of the fuel pump.....
and there could possibly be a flash update for the controller....not positve tho...
Old Sep 6, 2007 | 06:43 AM
HankL's Avatar
HankL
info:
http://web.archive.org/web/200206110...er/3378552.htm
https://dodgeforum.com/m_454739/mpag.../tm.htm#459127
