headlights
Can anyone help me? I'm a handicapped person, and I need to remove, and then install the headlight on my 1998 Dodge Intrepid ES (drivers side). Hope it won't be to hard to do. AGAIN PLEASE HELP!
THANKS
FREDDIE <><
THANKS
FREDDIE <><
Only required removal of 2 long screws.
These are vertically mounted on the top of the lamp housing. The require a very small socket (maybe 5.5mm???)
Pull lens out, remove wires and your home free.
This is to to the "LAST HONEST CAR DEALER", many thanks for your help! I was able to remove and install my new headlight on my car.
Just one more thing; now how can I adjust the "light beam?"
Freddie <><
Freddie <><
On your light should be the two levelers that show the pitch of your headlights. On the inside under your hood next to the headlights, you turn them. There should be one facing the engine compartment, And one pointing up toward the hood if it were closed. The top screw adjusts the inward-outward and the other adjusts your higher-lower tightening the top screw brings the light in toward the center of your lane. Loosening sends it outward toward the shoulder, the back screw tightening will bring it up. loosening will lower the beam if you can understand what i just said, god bless you, lol GL
