2nd Gen Intrepid 1998 through 2004 Intrepids
Front brakes squeak
Old Dec 27, 2006 | 03:25 PM
hexbolt's Avatar
hexbolt
Default Front brakes squeak
My 2002 Intrepid has a constant brake squeak. No matter if the calipers are depressed or not. Any suggestions on how to get them to stop. I already replaced the pads twice.
Old Dec 30, 2006 | 10:06 PM
kurts2's Avatar
kurts2
Default RE: Front brakes squeak
Did you try and turn the disks? Or better yet, replace them (when I did my brake job about 2 months ago, new disks were $15 and it usually costs $10 to turn them so I bought the new ones).
Old Jan 6, 2007 | 07:16 PM
hexbolt's Avatar
hexbolt
I replaced the Rotors and it still was squeeling. I ask a mechanic friend of mine and he suggested new Anti-rattle clips, or retractor clips. This helped somewhat. It still make a scraping or squeeling sound. possibly the Caliper assembly?
Old Jan 12, 2007 | 11:22 AM
decimon's Avatar
decimon
Inside of each front rotor is a cruddeflector madeof a thin metal. In time, the deflectors can bend in towards the rotors to make the noises you describe. Been there, cursed that.
You can easily bend the deflectors a bit away from the rotors to eliminate the problem. Something like 1/4 inch should do.
Old Feb 9, 2007 | 07:32 AM
hexbolt's Avatar
hexbolt
The noise I thought was coming from the brakes, is coming from the front wheel drive assembly. The noise is relative to how fast the car is traveling. So whether the brakes were applied or not, the sqealing was still present. It comes and goes as well. Sometimes its louder than the day before. Sometimes there is no noise at all. So, this will go on until I get time to look at it in detail. Thanks for the help.
Old Feb 9, 2007 | 11:45 AM
decimon's Avatar
decimon
hexbolt,
I went through everything you describe and the problem was nothing more than the spacing of the deflectors so I hope you've checked that.
The noise problem began after replacing the pads and rotors. The mechanic who did the job did it over at no charge. He didn't see the problem was with the deflectors. With the redoing of the pads/rotors, the noise went away for a time but then returned. I jacked up the car and rotated the wheels and never saw the problem. It may be that you will never see the problem with the car lifted.
It may be that your problem is other than this simplest-of-all-possible-fixes deflector problem but I can't see why you wouldn't take a screwdriver and bend out the deflectors to about 1/4" to find out. It's that easy so I hope you've done this.
