2nd Gen Intrepid 1998 through 2004 Intrepids
camshaft positioning sensor
Old Feb 14, 2007 | 03:19 PM
howlingwolf's Avatar
howlingwolf
Default camshaft positioning sensor
I own a 1999 Intrepid 2.7recently the check engine light came on, I took the car to a local auto parts store and they used a hand held analyzer and said the camshaft positioning sensor had gone bad. My question is where is this sensor located and is it a DIY project or should I have a shop do the job.?
Old Feb 15, 2007 | 12:15 AM
kurts2's Avatar
kurts2
Default RE: camshaft positioning sensor
I looked at the PDF in the post at the top of the 2nd gen fourm titled the holy grail. The page is 8I-3 that way you can se the picture. Is seems easy, I know the crank sensor is, but never changed the CAM sensor. It looks just as simple though. It should be the same for your 99 (the manual is for a 02) and here is an exerpt:
REMOVAL - 2.7L
The camshaft position sensor is mounted in the
front of the head.
(1) Disconnect electrical connector from sensor.
(2) Remove camshaft position sensor screw.
(3) Without pulling on the connector, pull the sensor
out of the chain case cover.
Old Feb 15, 2007 | 07:48 PM
howlingwolf
Thank You Very Much!!!
Old Feb 15, 2007 | 07:49 PM
howlingwolf
Old Feb 17, 2007 | 02:45 PM
kurts2's Avatar
kurts2
You are welcome. Did you change it?
Old Feb 18, 2007 | 11:23 AM
howlingwolf
No not yet, my other vehicle decided it needed some attention and blew the water pump.
Old Mar 21, 2007 | 09:21 PM
twinturbo's Avatar
twinturbo
easy to changre one bolt buy from dealer i know more money but i bought aftermarkets went through 2 in 8 months
